IPi Recorder Installation
Revision as of 19:49, 28 June 2012 by VMaslov (Talk | contribs)
Download the setup package of iPi Recorder latest version: http://files.ipisoft.com/iPiRecorderSetup.exe. Run it. In the following dialog window make sure that
  • item Playstation3 Eye Webcam :: WinUSB Drivers Registration is selected or marked as ALREADY INSTALLED if you plan to work with Sony PS Eye cameras
  • both items ASUS Xtion :: OpenNI Redistributable and ASUS Xtion :: PrimeSense Sensor are selected or marked as ALREADY INSTALLED if you plan to work with ASUS Xtion or ASUS Xtion Live depth sensors
  • item Microsoft Kinect :: MS Kinect SDK 1.5 is selected or marked as ALREADY INSTALLED if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect for XBOX 360 depth sensors
    Note 1. MS Kinect SDK is not supported on Windows versions prior to Windows 7. When running installer on those versions, select item Microsoft Kinect :: PrimeSense psdrv3.sys Driver Registration to work with Kinect sensors.
    Note 2. iPi Recorder does support working with Kinect sensors on Windows 7 using psdrv3.sys. If you have installed and used it for Kinect with iPi Recorder 1.x, you can continue to using it with iPi Recorder 2.
