IPi Recorder Installation
Revision as of 16:46, 22 July 2012 by VMaslov (Talk | contribs)
Download and run the setup package of iPi Recorder latest version: http://files.ipisoft.com/iPiRecorderSetup.exe. You will be presented with the following dialog.
  1. Select needed components
Components
  • Microsoft .NET Framework 4 - Client. This is required component and cannot be unchecked.
    This is basic infrastructure for running .NET programs. iPi Recorder is a .NET program.
    Can be downloaded from:
    • Web installer: [1]
    • Standalone installer: [2]
  • Playstation3 Eye Webcam :: WinUSB Drivers Registration. Check if you plan to work with Sony PS Eye cameras.
    • 64-bit OS: [3]
    • 32-bit OS: [4]
  • ASUS Xtion :: OpenNI Redistributable and ASUS Xtion :: PrimeSense Sensor. Check if you plan to work with ASUS Xtion or ASUS Xtion Live depth sensors.
    Device drivers and software libraries for ASUS Xtion / Xtion Live.
  • (Windows 7, 8) Microsoft Kinect :: MS Kinect SDK 1.5. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
  • (Windows XP, Vista) Microsoft Kinect :: PrimeSense psdrv3.sys Driver Registration. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
    Alternative device drivers for Microsoft Kinect.
  • Note. iPi Recorder does support working with Kinect sensors on Windows 7 using PrimeSense driver. If you have installed and used it for Kinect with iPi Recorder 1.x, you can continue to using it with iPi Recorder 2.
