IPi Recorder Installation
Download and run the setup package of iPi Recorder latest version: http://files.ipisoft.com/iPiRecorderSetup.exe. You will be presented with the following dialog.
- Select needed components
Components
This is basic infrastructure for running .NET programs. iPi Recorder is a .NET program.
Can be downloaded from:- Web installer: http://www.microsoft.com/en-us/download/details.aspx?id=17113
- ASUS Xtion :: OpenNI Redistributable and ASUS Xtion :: PrimeSense Sensor. Check if you plan to work with ASUS Xtion or ASUS Xtion Live depth sensors.
Device drivers and software libraries for ASUS Xtion / Xtion Live.
- (Windows 7, 8) Microsoft Kinect :: MS Kinect SDK 1.5. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
- (Windows XP, Vista) Microsoft Kinect :: PrimeSense psdrv3.sys Driver Registration. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
Alternative device drivers for Microsoft Kinect.
- 64-bit OS: http://files.ipisoft.com/drivers/KinectPsdrv3_iPi-x64.msi
- Note. iPi Recorder does support working with Kinect sensors on Windows 7 using PrimeSense driver. If you have installed and used it for Kinect with iPi Recorder 1.x, you can continue to using it with iPi Recorder 2.
