IPi Recorder Installation
Revision as of 16:53, 22 July 2012 by VMaslov (Talk | contribs)
Download and run the setup package of iPi Recorder latest version. You will be presented with the following dialog.
  1. Select needed components
Components
  • (Windows 7, 8) Microsoft Kinect :: MS Kinect SDK 1.5. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
  • (Windows XP, Vista) Microsoft Kinect :: PrimeSense psdrv3.sys Driver Registration. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
    Alternative device drivers for Microsoft Kinect.
    Note. iPi Recorder does support working with Kinect sensors on Windows 7 using PrimeSense driver. If you have installed and used it for Kinect with iPi Recorder 1.x, you can continue using it with iPi Recorder 2.
  • iPi Recorder 2.0.x. This is required component and cannot be unchecked.
    iPi Recorder itself.
