IPi Recorder Installation
- Select needed components
Components
Can be downloaded from:
- ASUS Xtion :: OpenNI Redistributable and ASUS Xtion :: PrimeSense Sensor. Check if you plan to work with ASUS Xtion or ASUS Xtion Live depth sensors.
Device drivers and software libraries for ASUS Xtion / Xtion Live.
- (Windows 7, 8) Microsoft Kinect :: MS Kinect SDK 1.5. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
- (Windows XP, Vista) Microsoft Kinect :: PrimeSense psdrv3.sys Driver Registration. Check if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect XBOX 360 depth sensors.
- iPi Recorder 2.0.x. This is required component and cannot be unchecked.
iPi Recorder itself.
