Cameras and accessories
Recommended camera for use with iPi Desktop Motion Capture is Sony PlayStation 3 Eye.
- High frame rate - up to 60 frames per second (important for reducing motion blur and capturing fast motions like dancing, boxing or running).
- Very good low-light sensitivity.
- Low-distortion wide-angle fixed optics.
- Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams).
- Low cost (under $40).
Cables
You will need USB 2.0 extension cables. For distances over 5m, you should use active USB 2.0 extension cables. You can daisy-chain multiple active USB 2.0 extension cables for distances longer than 10m. When combining active and passive cables, make sure that the connection order is correct (computer->active cable->passive cable->camera).
Tripods
Video Card
iPi Desktop Motion Capture relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Please be aware that desktop GPUs are dramatically faster than notebook GPUs (due to apparent thermal constraints in notebook PCs). To give you an idea of potential performance for various GPU models below are some benchmark results:
