IPi Recorder User's Guide
Revision as of 16:40, 24 July 2012 by VMaslov (Talk | contribs)
Common
General UI layout
Recorder
Cameras stage
Setup
  • Select working video mode
  • Reorder cameras.
    Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area — either clockwise, or counter-clockwise. This will make calibration process in Studio much simpler.
Selecting video mode Reordering cameras Camera properties
Background
Record
Player
Converter
