IPi Recorder User's Guide
Revision as of 15:44, 27 July 2012 by VMaslov (Talk | contribs)
Common
General UI layout
On-Screen Controls
  • Enter full screen mode
On-screen controls Full screen mode
Recorder
Cameras stage
Setup
  • Select working video mode
  • Reorder cameras.
    Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area — either clockwise, or counter-clockwise. This will make calibration process in Studio much simpler.
Selecting video mode Reordering cameras Camera properties
Background
Background is not evaluated yet Counting down for delayed start Background is already evaluated
Record
Player
Converter
Tools
