USB controllers
- 2 depth sensors (MS Kinect or ASUS Xtion)
USB hubs
Some notebook PCs have one of integrated USB 2.0 controllers reserved for docking station. That may effectively halve your USB bandwidth. Desktop PCs should not have such problem.
If you plan getting an additional USB controller, please be aware of potential problems with USB 2.0 controllers available on the market. Many USB 2.0 controllers are based on defective NEC USB 2.0 chip, not capable of standard USB 2.0 speeds. That's a well-known bug specific only to NEC USB 2.0 chip. By contrast, all NEC USB 3.0 chips are good and do not have this problem. Some manufacturers sell what they call a "USB 2.0 ExpressCard" controller for notebook PCs. Many of such ExpressCard controllers are in fact internal USB hubs in ExpressCard form factor. That means they do not add actual USB bandwidth to the system.
