Revision as of 15:54, 14 August 2012 by Pavel (Talk | contribs)
iPi Studio
Note that before you start working with two Kinects it's highly recommended to get appropriate results with single Kinect solution: User Guide for Single Kinect Sensor Configuration.
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
iPi Mocap Studio
Environment
Side view
Top view
Actor Clothing
Recording Process
Calibration
The first configuration
Top view
Side view
Preparations
Good
Bad
good size
good depth data
too small
too close to human body
Recording Calibration Video
Good
Bad
Processing Calibration Video
  • Adjust the end of ROI:
  • Evaluate the result:
  • Save the result:
    • go to the Scene tab
The second configuration
Top view
Side view
Preparations
Good
Bad
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
  • switch to the Scene tab
  • etc.
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Step 5
Step 5
Step 5
Step 6
Installation problems
How to report bugs and issues
Video Materials
