Calibration
Importance of high frame rate
Glowing Marker
Run iPiRecorder and choose one of the darkening modes in "darkening for calibration" list (for Sony PS Eye cameras)
- Important! Do not turn off the light in the room during calibration! This will not help the software but will make it harder for you to see what is happening on recorded video when you view it later.
Start video recording. First couple of seconds of calibration video should contain background only (no marker). Then move slowly the marker through your entire capture volume (front-top-right-bottom-left-back-top-right-bottom-left). Start from top and move the marker in a descending spiral motion.
Put the marker to the ground at each corner and at the center of capture volume.
- First two seconds of video do not contain marker
Step 5: process calibration video in iPiStudio
- Load your calibration video to iPiStudio
- VERY IMPORTANT: Adjust the Region of Interest to cover the part of video that contains the glowing marker.
- Set initial positions of cameras. Move and rotate virtual cameras so that their positions and orientations very roughly correspond to real positions and orientations. Click “Calibrate” button on “Calibration” tab and wait while the system finishes calibration.
- Calibration algorithm may occasionally fail to find correct camera position. In particular, this may happen if left and right cameras are swapped. If this happens, move virtual cameras using camera orbit control on “Scene” tab and click “Calibrate” again. This will cause calibration (but not marker tracking) to be repeated.
Follow video tutorial:
Step 6: Define ground plane
