User Guide for Dual Depth Sensor Configuration (printable version)
Quick Start Guide
For the impatient:
- Get two Microsoft Kinect sensors, or ASUS Xtion Live sensors, or PrimeSense Carmine 1.08 sensors
- Get computer with DirectX 10 videocard and at least two USB 2.0 or 3.0 controllers
- Download iPi Recorder and iPi Mocap Studio
- Install iPi Recorder and iPi Mocap Studio
- Connect depth sensors to PC
- Note that both sensors can't be connected through one and the same USB 2.0/3.0 controller
- Point them at the actor (the angle between two depth sensors can be in the range 60-90 degrees, or near to 180 degrees)
- For calibration, take flat rectangular cardboard, and use iPi Recorder to record calibration video
- Please ensure that the calibration board is visible in both sensors. Turn the calibration board to the left and to the right, holding it vertically in front of yourself on outstretched arms.
- Record video of actor's performance. Please ensure that the whole body including arms and legs is visible during the performance in both sensors. Start from a T-pose. Then goes actor’s performance.
- Run iPi Mocap Studio to process actor performance video
- Import your character into iPi Mocap Studio (File >Import Target Character) to adapt the animation for your character rig
User Guide
- Storage system: HDD or SSD or RAID with write speed at least 55 MByte/sec
- Two Microsoft Kinect sensors, or ASUS Xtion Live sensors, or PrimeSense Carmine 1.08 sensors
iPi Mocap Studio
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
iPi Mocap Studio
Environment
Actor Clothing
Recording Process
Calibration
First configuration
Preparations
- make sure that this calibration board is good visible in both sensors (the amount of yellow is low in the area of the board).
Recording Calibration Video
- Start recording by pressing the "Start" button.
- Go to the capture area with the prepared calibration board.
- Move the board back and forth, slight tipping and banking, plus slight side-to-side rotation.
- Stop the recording by pressing the "Stop" button.
- The calibration board is good visible on the depth maps most the time
- The calibration board is moving and has variety in distances to the sensors
- The amount of yellow points is relatively small
Processing Calibration Video
- Please make sure that the ground plane is determined correctly for both sensors after calibration video opening in the iPi Studio (to switch between sensors use buttons "Camera 1" and "Camera 2" in the top toolbar).
- Set the beginning of Region of Interest (ROI) to the point where calibration plane is good visible in both sensors.
- Adjust the end of ROI:
- the length of ROI should be at leat 5 seconds (150 frames)
- Go to the Calibration tab and click "Calibrate Based on 3D Plane" button
- Please wait for the end of calibration process
- Evaluate the result:
- Save the result:
- go to the Scene tab
Second configuration
Preparations
It's mostly similar to processing of the first configuration.
Recording Actor's Performance
Performance Tips
- Enter the actor.
- Strike a T-pose.
- Action
T-pose
Takes
Iterations
- Record the videos
- Give feedback to the actor
Takes
Naming conventions
- switch to the Scene tab
- select file with scene parameters which has been saved during calibration process
- etc.
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Installation problems
How to report bugs and issues
Video Materials
- From Jimer Lins: Part 1 - Setting up your Kinects and Calibrating
- From Jimer Lins: Part 2 - Recording the Action
- From Jimer Lins: Part 3 - Processing the Recorded Action
- From Jimer Lins: see other parts
USB controllers
- Very good low-light sensitivity.
- Low-distortion wide-angle fixed optics.
- Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams).
- Low cost (under $40).
Cables
Tripods
Video Card
iPi Mocap Studio relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Intel integrated graphics is not supported
Please be aware that desktop GPUs are dramatically faster than laptop GPUs (due to apparent thermal constraints in laptop PCs). Laptops with switchable graphics should be configured to run iPi Mocap Studio on a discrete (high-performance) GPU.
USB controllers
- 2 depth sensors (MS Kinect, or ASUS Xtion, or PrimeSense Carmine)
USB hubs
Known compatibility issues
| ASUS Xtion (Live) | NEC µPD720200 (USB3) | Camera is not properly recognized by the system. | This firmware update makes device behave the same as PrimeSense Carmine 1.08 with this controller. |
| ASUS Xtion (Live) | VIA VT6212L (USB2) | Frame drops of color picture in 640x480@30 (depth + color). | |
| PrimeSense Carmine 1.08 | NEC µPD720200 (USB3) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VT6212L (USB2) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VL800(USB3) | Frame drops, reduced frame rate, freezes in depth + color modes. | Stable work in depth only modes. |
| Sony Playstation Eye | VIA VL800 (USB3) | Great number of bad frames and frame drops. Camera is invisible to iPi Recorder. | |
| Sony Playstation Eye | VIA VT6212L (USB2) | Great number of frame drop in 640x480@60 mode. | 2 cameras can work smoothly at lower FPS (up to 640x480@50). |
