User Guide for Single Depth Sensor Configuration (printable version)
Revision as of 12:03, 11 September 2012 by Andrew (Talk | contribs)
iPi Mocap Studio
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
iPi Mocap Studio
Environment
Side view
Top view
Actor Clothing
Recording Process
iPi Recorder Setup
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
  • Run iPi Mocap Studio
    3. Right mouse button up
  • Wait and watch...
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Step 5
Step 5
Step 5
Step 6
Installation problems
How to report bugs and issues
Video Materials
Demo video
"Car scene" by JeanDellac
Click to view
Animation by NextGenReport
