User Guide for Dual Depth Sensor Configuration (printable version)
Revision as of 12:06, 11 September 2012 by Andrew (Talk | contribs)
iPi Mocap Studio
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
iPi Mocap Studio
Environment
Side view
Top view
Actor Clothing
Recording Process
Calibration
First configuration
Top view
Side view
Preparations
Good
Bad
good size
good depth data
too small
too close to human body
Recording Calibration Video
Good
Bad
Processing Calibration Video
  • Adjust the end of ROI:
  • Evaluate the result:
  • Save the result:
    • go to the Scene tab
Second configuration
Top view
Side view
Preparations
Good
Bad
It's mostly similar to processing of the first configuration.
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
  • switch to the Scene tab
  • etc.
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Step 5
Step 5
Step 5
Step 6
Installation problems
How to report bugs and issues
Video Materials
USB controllers
  • Low cost (under $40).
Cables
Tripods
Video Card
iPi Mocap Studio relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Intel integrated graphics is not supported
Please be aware that desktop GPUs are dramatically faster than laptop GPUs (due to apparent thermal constraints in laptop PCs). Laptops with switchable graphics should be configured to run iPi Mocap Studio on a discrete (high-performance) GPU.
USB controllers
USB hubs
Known compatibility issues
