User Guide for Single Depth Sensor Configuration (printable version)
For the impatient:
- Get the Microsoft Kinect sensor, or ASUS Xtion Live sensor, or PrimeSense Carmine 1.08 sensor
- Get computer with DirectX 10 videocard
- Download iPi Recorder and iPi Mocap Studio
- Install iPi Recorder and iPi Mocap Studio
- Connect depth sensor to a PC, point it at the actor and use iPi Recorder to record your performance
- Please ensure that the whole body including arms and legs is visible during the performance. Start from a T-pose. Then goes actor’s performance
- Run iPi Mocap Studio process actor performance video. Refer to iPi Soft Motion Capture Workflow from Paul Stapelberg for instructions on how to
- Import your character into iPi Mocap Studio (File->Import Target Character) to adapt the animation for your character rig
- Microsoft Kinect sensor, or ASUS Xtion Live sensor, or PrimeSense Carmine 1.08 sensor
iPi Mocap Studio
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
iPi Mocap Studio
Environment
Actor Clothing
Recording Process
Recording Actor's Performance
Performance Tips
- Enter the actor.
- Strike a T-pose.
- Action
T-pose
Takes
Iterations
- Record the videos
- Give feedback to the actor
Takes
Naming conventions
- Press Ctrl+N or push New button on toolbar to create new project
- Choose recorded *.iPiVideo file
- Right mouse button up
- Save created project by pressing Ctrl+S or pushing button Save on toolbar
- Adjust actor height using appropriate slider on tab Actor
- Select Move tool on toolbar.
- Switch to Tracking tab and push Refit pose button.
- As a result model should be matched with actor image from video. If it does not happen then delete result using item Edit > Delete pose from main menu and repeat above actions.
- Using the slider right to the button Show Skin in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust chest/bust/waist/hips/belly morph using appropriate sliders from Actor tab.
- Switch to Tracking tab, change tracking options (Head tracking, Shoulders and Spine) if required.
- To start tracking just push Track Forward button.
- Wait and watch...
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Installation problems
How to report bugs and issues
Video Materials
Demo video
"Car scene" by JeanDellac
Animation by NextGenReport
