IPi Recorder Changelog
Revision as of 22:23, 13 September 2012 by Andrew (Talk | contribs)
ver. 2.0.0.14
Version 2.0.0.14
Jul 21, 2012
Download-24.png  Download
 N E W    F E A T U R E S:
  • Improved error handling.
 B U G    F I X E S:
ver. 2.0.0.13
Version 2.0.0.13
Jun 14, 2012
WARNING. iPi Mocap Studio prior to version 2.0.0.132 may not open videos recorded with this release of iPi Recorder. Ensure that you're using the latest version of iPi Mocap Studio (see version info in Help -> About window). In case you need an update, try restarting application (an automatic update should launch), or download and run the latest installer from the downloads page at our website. Videos recorded with previous versions of iPi Recorder can still be opened by any version of iPi Mocap Studio.
ver. 2.0.0.12
Version 2.0.0.12
Jun 05, 2012
Note. Currently, the auto update feature is configured so that checks for update are made once per day. It helps to reduce the start time of the application. If you've noticed an announcement about new release on this forum or elsewhere, and you want to update ASAP - you can use the CHECK FOR UPDATE button. Alternatively (or for quick update from previous releases not having this button), you can download and run the updated installation program from our website.
 B U G    F I X E S:
ver. 2.0.0.11
Version 2.0.0.11
Jun 05, 2012
 B U G    F I X E S:
ver. 2.0.0.10
Version 2.0.0.10
Jun 01, 2012
