IPi Mocap Studio Changelog
iPi Mocap Studio has build-in auto update functionality. Auto update feature is configured so that checks for update are made once per day. It helps to reduce the start time of the application. If you want to update ASAP - you can use the Help -> Check for Update menu item.
ver. 2.1.0.139
N E W F E A T U R E S:
- Note. Currently does not track face orientation, that is head rotation around Y axis.
- More compact project files.
B U G F I X E S:
ver. 2.0.1.138
ver. 2.0.0.137
- Improvements in FBX import concerning character skining.
B U G F I X E S:
ver. 2.0.0.135
B U G F I X E S:
- Fixed error in activation code. This issue is discussed in and http://forum.ipisoft.com/viewtopic.php?f=5&t=6158.
ver. 2.0.0.134
B U G F I X E S:
ver. 2.0.0.133
B U G F I X E S:
- Fixed rounding error causing incorrect value of frames per second. This issue is discussed in [2].
- Fixed incorrect background processing. This issue is discussed in [3].
- Fixed application failures when returning from logon screen and standby mode. This issue was primarily discussed by email. Partial discussion is in [4].
- Fixed ignoring the Export T-pose in first frame option and Recenter coordinate system on character in first frame checkboxes. This issue is discussed in [5].
ver. 2.0.0.132
B U G F I X E S:
ver. 2.0.0.131
B U G F I X E S:
- Fixed startup error occuring on some WinXP/Vista computers. This issue is discussed in [6].
ver. 2.0.0.130
B U G F I X E S:
ver. 2.0.0.129
- New skeleton.
- New project wizard.
- Improved foot tracking.
- Improved shoulder tracking.
