IPi Recorder Changelog
Revision as of 20:28, 1 October 2012 by Andrew (Talk | contribs)
iPi Recorder has build-in auto update functionality. Auto update feature is configured so that checks for update are made once per day. It helps to reduce the start time of the application. If you want to update ASAP - you can use the CHECK FOR UPDATE button.
ver. 2.0.0.15
Version 2.0.0.15
Oct 01, 2012
Download-24.png  Download
 N E W    F E A T U R E S:
  • Improved alignment of depth and color images.
    Device-specific parameters are obtained for each depth sensor and written to iPiVideo file during recording. This gives high accuracy of aligning depth and color images in iPi Mocap Studio. Implemented both for Microsoft Kinect and ASUS Xtion Live.
  • Opening video in iPi Mocap Studio with one click.
    Each recorded or converted video file in addition to existed Play button now has Open In Studio button (icon is letter "S"). Press this button, and (if installed) iPi Mocap Studio will launch with the New Project wizard open for the selected video file.
  • New help menu.
    Contains user's guide, release notes and EULA.
  • Further performance improvements
 B U G    F I X E S:
  • Frame drops statistics were not counted properly for ASUS Xtions.
  • Under certain circumstances empty video were recorded (containing no frames).
ver. 2.0.0.14
Version 2.0.0.14
Jul 21, 2012
  • Improved error handling.
 B U G    F I X E S:
ver. 2.0.0.13
Version 2.0.0.13
Jun 14, 2012
WARNING. iPi Mocap Studio prior to version 2.0.0.132 may not open videos recorded with this release of iPi Recorder. Ensure that you're using the latest version of iPi Mocap Studio (see version info in Help -> About window). In case you need an update, try restarting application (an automatic update should launch), or download and run the latest installer from the downloads page at our website. Videos recorded with previous versions of iPi Recorder can still be opened by any version of iPi Mocap Studio.
ver. 2.0.0.12
Version 2.0.0.12
Jun 05, 2012
 B U G    F I X E S:
ver. 2.0.0.11
Version 2.0.0.11
Jun 05, 2012
 B U G    F I X E S:
ver. 2.0.0.10
Version 2.0.0.10
Jun 01, 2012
