IPi Recorder Changelog
iPi Recorder has build-in auto update functionality. Auto update feature is configured so that checks for update are made once per day. It helps to reduce the start time of the application. If you want to update ASAP - you can use the tools -> check for update menu item.
ver. 2.1.0.17
N E W F E A T U R E S:
- Support for motion controllers — Sony PlayStation Move and Nintendo Wii Remote (with Motion Plus)
- This enables props/hands tracking in iPi Mocap Studio (update with these capabilities will be available in the next 2-3 weeks). See our Getting Started guide.
- Video information panel in player
- Expand it from the right edge of the window and explore all information stored in iPiVideo file: camera models, property values used during recording, statistical data, etc.
- Little UI improvements, including:
- auto hiding on-screen controls when the mouse is still for a while
- auto selecting value for devices in a row (cameras in a row in previous versions) depending on the number of devices
- Decreased memory usage.
ver. 2.0.0.15
- Improved alignment of depth and color images.
- Device-specific parameters are obtained for each depth sensor and written to iPiVideo file during recording. This gives high accuracy of aligning depth and color images in iPi Mocap Studio. Implemented both for Microsoft Kinect and ASUS Xtion Live.
- Opening video in iPi Mocap Studio with one click.
- Each recorded or converted video file in addition to existed Play button now has Open In Studio button (icon is letter "S"). Press this button, and (if installed) iPi Mocap Studio will launch with the New Project wizard open for the selected video file.
- New help menu.
- Contains user's guide, release notes and EULA.
- Further performance improvements
B U G F I X E S:
- Frame drops statistics were not counted properly for ASUS Xtions.
- Under certain circumstances empty video were recorded (containing no frames).
- The installer won't run on Windows XP x64.
ver. 2.0.0.14
- Preventing from going to screensaver/stand by mode. Works for Recorder (starting from Setup stage), Player (when playing), Converter (only standby, when converting).
- JPEG compression is supported for all source camera image formats. Also its performance is improved.
- Note 1. JPEG compression reduces quality of source image. For color cameras (not depth sensors), use it only when really necessary (e.g. your system is low on disk space or writing speed).
- Note 2. PS Eye videos recorded with JPEG compression would not be read with iPi Mocap Studio prior to version 2.0.0.137. Please ensure you have updated to compatible version.
- Improved performance for PS Eye recording.
- Default folder for storing recorded videos is set to user's documents folder.
- Note. By an oversight, in previous versions default folder was set to iPi Recorder's installation folder. That is something like C:\Users\<username>\AppData\Local\Apps\2.0\B5TATZ4A.47Z\CN6K71PK.J0W\ipir..tion_dd200afcf7b6b7ee_0002.0000_c0485bd65ddfb5d4 (on Windows Vista/7) or C:\Documents and Settings\<username>\Local Settings\Apps\2.0\B5TATZ4A.47Z\CN6K71PK.J0W\ipir..tion_dd200afcf7b6b7ee_0002.0000_c0485bd65ddfb5d4 (on Windows XP). Path parts after Apps\2.0 contain some "random" characters defined by specific system installation. In case you did not change that default folder, your records might be deleted when updating or uninstalling iPi Recorder. To be on the safe side, please check if you still have .iPiVideo or .iPiMocap files somewhere under mentioned ...\Apps\2.0 folder and, if found any, move them to some "normal" location.
- More reliable counting of frame drops.
- Improved error handling.
B U G F I X E S:
- Fixed the issue causing crash during recording (see [1]).
- Fixed the issue causing hang up during conversion of certain AVI files (see [2]).
ver. 2.0.0.13
- Improved speed performance for the Background subtraction compression method, and depth channel compression. This should help to resolve frame drops issues that some users experience when recording, especially from PS Eye cameras.
- WARNING. iPi Mocap Studio prior to version 2.0.0.132 may not open videos recorded with this release of iPi Recorder. Ensure that you're using the latest version of iPi Mocap Studio (see version info in Help -> About window). In case you need an update, try restarting application (an automatic update should launch), or download and run the latest installer from the downloads page at our website. Videos recorded with previous versions of iPi Recorder can still be opened by any version of iPi Mocap Studio.
ver. 2.0.0.12
- Check for version update from the application. To check, open the tools menu and click the CHECK FOR UPDATE button. If update is detected, you will be prompted to manually restart the application to perform an update.
B U G F I X E S:
- Fixed freezing when detecting available cameras after calibration mode was used with PS Eye cameras. This issue is discussed in [3].
- Restored support for PSDRV3 drivers for Kinect on Windows 7, which was silently removed in the previous release. Sorry for inconvenience, folks. However, we strongly recommend to use Kinect SDK for recording with Kinects on Windows 7. This issue is discussed in [4].
ver. 2.0.0.11
- Added the tools menu. It is located in the top-right corner, where previously the version number was displayed. Currently, the menu contains the version number and the SHOW TRACE button.
- Added functionality for displaying the program trace and saving it to a file. To display trace window, press the SHOW TRACE button located under the tools menu. Program trace contains diagnostic messages produced by software. When iPi Recorder is not working properly, you can save the trace and attach to your issue report. It may help us in investigation of the issue.
- Some performance improvements.
B U G F I X E S:
ver. 2.0.0.10
