IPi Mocap Studio Changelog
Revision as of 15:11, 7 November 2012 by Andrew (Talk | contribs)
ver. 2.1.2.141
Version 2.1.2.141
Nov 07, 2012
Download-24.png  Download
 N E W    F E A T U R E S:
ver. 2.1.1.140
Version 2.1.1.140
Oct 13, 2012
  • Small UI improvements:
Select bone
MRU project list
Export animation button
ver. 2.1.0.139
Version 2.1.0.139
Sep 30, 2012
UI changes
  • More compact project files.
 B U G    F I X E S:
ver. 2.0.1.138
Version 2.0.1.138
Aug 04, 2012
Note. To turn off this alignment one can use View -> Align Color Video to Depth menu item.
ver. 2.0.0.137
Version 2.0.0.137
Jul 19, 2012
  • Improvements in FBX import concerning character skining.
 B U G    F I X E S:
ver. 2.0.0.135
Version 2.0.0.135
Jul 03, 2012
 B U G    F I X E S:
ver. 2.0.0.134
Version 2.0.0.134
Jun 30, 2012
  • Support for any order of Euler angles in FBX export. This is especially useful for LightWave users. See this topic list for discussions about this problem.
 B U G    F I X E S:
ver. 2.0.0.133
Version 2.0.0.133
Jun 17, 2012
 B U G    F I X E S:
  • Fixed rounding error causing incorrect value of frames per second. This issue is discussed in [2].
  • Fixed incorrect background processing. This issue is discussed in [3].
  • Fixed application failures when returning from logon screen and standby mode. This issue was primarily discussed by email. Partial discussion is in [4].
  • Fixed ignoring the Export T-pose in first frame option and Recenter coordinate system on character in first frame checkboxes. This issue is discussed in [5].
ver. 2.0.0.132
Version 2.0.0.132
Jun 13, 2012
 B U G    F I X E S:
ver. 2.0.0.131
Version 2.0.0.131
Jun 07, 2012
 B U G    F I X E S:
  • Fixed startup error occuring on some WinXP/Vista computers. This issue is discussed in [6].
ver. 2.0.0.130
Version 2.0.0.130
Jun 02, 2012
  • Different menu item and toolbar button for creating new project (File -> New project… and New respectively).
  • File -> Open is renamed to File -> Open project… and now opens only project files.
  • File -> Import animation menu item is renamed to File -> Open animation…
 B U G    F I X E S:
ver. 2.0.0.129
Version 2.0.0.129
Jun 01, 2012
  • New skeleton.
  • New project wizard.
  • Improved foot tracking.
  • Improved shoulder tracking.
