IPi Mocap Studio Changelog
ver. 2.1.2.142
B U G F I X E S:
- Importing of some target characters doesn't work
- Version is not visible in About box
ver. 2.1.2.141
N E W F E A T U R E S:
ver. 2.1.1.140
- Small UI improvements:
ver. 2.1.0.139
- More compact project files.
B U G F I X E S:
ver. 2.0.1.138
ver. 2.0.0.137
- Improvements in FBX import concerning character skining.
B U G F I X E S:
ver. 2.0.0.135
B U G F I X E S:
- Fixed error in activation code. This issue is discussed in and http://forum.ipisoft.com/viewtopic.php?f=5&t=6158.
ver. 2.0.0.134
B U G F I X E S:
ver. 2.0.0.133
B U G F I X E S:
- Fixed rounding error causing incorrect value of frames per second. This issue is discussed in [2].
- Fixed incorrect background processing. This issue is discussed in [3].
- Fixed application failures when returning from logon screen and standby mode. This issue was primarily discussed by email. Partial discussion is in [4].
- Fixed ignoring the Export T-pose in first frame option and Recenter coordinate system on character in first frame checkboxes. This issue is discussed in [5].
ver. 2.0.0.132
B U G F I X E S:
ver. 2.0.0.131
B U G F I X E S:
- Fixed startup error occuring on some WinXP/Vista computers. This issue is discussed in [6].
ver. 2.0.0.130
B U G F I X E S:
ver. 2.0.0.129
- New skeleton.
- New project wizard.
- Improved foot tracking.
- Improved shoulder tracking.
