IPi Recorder Changelog
Revision as of 10:49, 3 December 2012 by Andrew (Talk | contribs)
iPi Recorder has built-in auto update functionality. Auto update feature is configured so that checks for update are made once per day. It helps to reduce the start time of the application. If you want to update ASAP - you can use the tools -> check for update menu item.
ver. 2.1.2.19
Version 2.1.2.19
Dec 03, 2012
Download-24.png  Download
 N E W    F E A T U R E S:
  • Taking advantage of new features of Kinect SDK 1.6:
    • depth data is not limited by 4 meters now
    • color image from Kinect is obtained as raw Bayer rather then decoded RGB which allows to improve performance of recording and reduce size of resulted *.iPiVideo file
    • PROPERTY page for Kinect for Windows devices now contains settingы for color camera (see screenshot). Note that this feature is not available for Kinect for XBOX
  • Significant performance improvements
New properties of Kinect for Windows
ver. 2.1.1.18
Version 2.1.1.18
Nov 25, 2012
  • Support for Nintendo Wii Remote Plus motion controller
  • Moved to Microsoft Kinect SDK 1.6
    Warning. Kinect SDK 1.6 should be installed to get support for Kinects with this version of iPi Recorder.
  • Start/stop recording using a motion controller. Hold the button for a couple of seconds to toggle recording. Also works when starting background evaluation.
    • Start button on PS Move
    • A button on Wii Remote
  • Indication of battery charge level for motion controllers
  • Sequential background evaluation for depth sensors. This removes infrared interference effects on background picture.
    Tip. In case you are going away from PC when evaluating background, be aware that now for dual sensor configuration, background evaluation lasts about twice the duration setting.
  • Detecting when too many cameras are connected to a single USB controller
  • Optimizing application performance (especially startup time) for the system on which it is installed (using NGen)
    tools > optimize app menu item
  • Launching Windows Device Manager directly from the menu
    tools > device manager menu item
  • Improved persistence of settings for motion controllers
 B U G    F I X E S:
  • Mixing up of Kinect motor controls occasionally when using PrimeSense drivers
Battery charge level
ver. 2.1.0.17
Version 2.1.0.17
Nov 03, 2012
  • Support for motion controllers — Sony PlayStation Move and Nintendo Wii Remote (with Motion Plus)
    This enables props/hands tracking in iPi Mocap Studio (update with these capabilities will be available in the next 2-3 weeks). See our Getting Started guide.
  • Video information panel in player
    Expand it from the right edge of the window and explore all information stored in iPiVideo file: camera models, property values used during recording, statistical data, etc.
  • Little UI improvements, including:
    • auto hiding on-screen controls when the mouse is still for a while
    • auto selecting value for devices in a row (cameras in a row in previous versions) depending on the number of devices
  • Decreased memory usage.
Motion controller (right)
Video info panel
ver. 2.0.0.15
Version 2.0.0.15
Oct 01, 2012
  • Improved alignment of depth and color images.
    Device-specific parameters are obtained for each depth sensor and written to iPiVideo file during recording. This gives high accuracy of aligning depth and color images in iPi Mocap Studio. Implemented both for Microsoft Kinect and ASUS Xtion Live.
  • Opening video in iPi Mocap Studio with one click.
    Each recorded or converted video file in addition to existed Play button now has Open In Studio button (icon is letter "S"). Press this button, and (if installed) iPi Mocap Studio will launch with the New Project wizard open for the selected video file.
  • New help menu.
    Contains user's guide, release notes and EULA.
  • Further performance improvements
 B U G    F I X E S:
  • Frame drops statistics were not counted properly for ASUS Xtions.
  • Under certain circumstances empty video were recorded (containing no frames).
  • The installer won't run on Windows XP x64.
ver. 2.0.0.14
Version 2.0.0.14
Jul 21, 2012
  • Improved error handling.
 B U G    F I X E S:
ver. 2.0.0.13
Version 2.0.0.13
Jun 14, 2012
WARNING. iPi Mocap Studio prior to version 2.0.0.132 may not open videos recorded with this release of iPi Recorder. Ensure that you're using the latest version of iPi Mocap Studio (see version info in Help -> About window). In case you need an update, try restarting application (an automatic update should launch), or download and run the latest installer from the downloads page at our website. Videos recorded with previous versions of iPi Recorder can still be opened by any version of iPi Mocap Studio.
ver. 2.0.0.12
Version 2.0.0.12
Jun 05, 2012
 B U G    F I X E S:
ver. 2.0.0.11
Version 2.0.0.11
Jun 05, 2012
 B U G    F I X E S:
ver. 2.0.0.10
Version 2.0.0.10
Jun 01, 2012
