Sample video and project (single depth sensor)
Revision as of 18:36, 19 December 2012 by Andrew (Talk | contribs)
Performance Sequence
Here you can download sample video file captured with the aid of depth sensor (MS Kinect) and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
Download video file
silly_kungfu.iPiVideo
40 Mb
 Video-256.png         Proj-256.png Download project file
silly_kungfu.iPiMocap
2 Mb
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select silly_kungfu.iPiMocap file downloaded on the previous step.
    • click 'New button or press Ctrl+N;
    • select silly_kungfu.iPiVideo file downloaded before;
    • then follow instructions to process video.
Exported Animation
iPi Skeleton
for 3D MAX Biped
for Motion Builder
for Blender
for iClone
for Endorphin
iPi Skeleton
for Motion Builder
for Endorphin
