Sample video and project (single depth sensor)
Performance Sequence
Here you can download sample video file captured with the aid of depth sensor (MS Kinect) and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
| Download video file silly_kungfu.iPiVideo 40 Mb | Download project file silly_kungfu.iPiMocap 2 Mb |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select silly_kungfu.iPiMocap file downloaded on the previous step.
- click 'New button or press Ctrl+N;
- select silly_kungfu.iPiVideo file downloaded before;
- then follow instructions to process video.
Exported Animation
iPi Skeleton for 3D MAX Biped for Motion Builder for iClone for Endorphin |
iPi Skeleton for Motion Builder for Endorphin |
iPi Skeleton |
Sandro |
