Motion in Joy Installation
- Currently (Jan 22, 2013) the latest version is 0.7.1001 which can be downloaded from the following direct link: http://www.xinputer.com/download/MotioninJoy_071001_signed.zip
Run installation application from the downloaded package:
- Note that for correct operation of this tool working Internet connection is required.
- Note that if your computer is equipped with more than one bluetooth adapters it's desirable to switch off or unplug all but one.
Pairing
Detection in iPi Recorder
