Motion in Joy Installation
Revision as of 15:03, 22 January 2013 by Andrew (Talk | contribs)
Run installation application from the downloaded package:
Pairing
Click Pair Now. As a result fields Adapter MAC' and Have Paired to should have one and the same value (note that exact value in your case will be different):
Unplug PS Move device from the computer and press PS button on it. Red LED should constantly glow. This means that pairing succeeds.
Detection in iPi Recorder
Notes
