Motion in Joy Installation
Revision as of 15:08, 22 January 2013 by Andrew (Talk | contribs)
Run installation application from the downloaded package:
Pairing
Click Pair Now. As a result fields Adapter MAC' and Have Paired to should have one and the same value (note that exact value in your case will be different):
Unplug PS Move device from the computer and press PS button on it. Red LED should constantly glow. This means that pairing succeeds.
Detection in iPi Recorder
Run iPi Recorder. All paired and switched on PS Move devices should be visible and have MotioninJoy logo near device picture:
Following instructions can be found in Getting started with motion controllers article.
Notes
