Motion in Joy Installation
Revision as of 15:52, 22 January 2013 by Andrew (Talk | contribs)
For some reason under Windows 8 standard pairing procedure doesn't work. To resolve this issue starting from version 2.1.3.20 iPi Recorder supports Motion in Joy solution as a workaround.
Pairing
Click Pair Now. As a result fields Adapter MAC' and Have Paired to should have one and the same value (note that exact value in your case will be different):
Unplug PS Move device from the computer and press PS button on it. Red LED should constantly glow. This means that pairing succeeds.
Detection in iPi Recorder
Following instructions can be found in Getting started with motion controllers article.
Notes
N O T E   1:
N O T E   2:
    • click Driver Manager
    • click Roll back
N O T E   3:
Drivers from MotioninJoy is not stable enough. Thus in rare cases you can account some issues including Blue Screen Error.
N O T E   4:
