Motion in Joy Installation
- Currently (Jan 22, 2013) the latest version is 0.7.1001 which can be downloaded from the following direct link: http://www.xinputer.com/download/MotioninJoy_071001_signed.zip
- Note that for correct operation of this tool working Internet connection is required.
- Note that if your computer is equipped with more than one bluetooth adapters it's desirable to switch off or unplug all but one.
Pairing
Click Pair Now. As a result fields Adapter MAC' and Have Paired to should have one and the same value (note that exact value in your case will be different):
Unplug PS Move device from the computer and press PS button on it. Red LED should constantly glow. This means that pairing succeeds.
Detection in iPi Recorder
Following instructions can be found in Getting started with motion controllers article.
Notes
N O T E 1:
N O T E 2:
- Use the second bluetooth adapter to communicate with ordinal bluetooth devices.
- click Driver Manager
- click Roll back
N O T E 3:
Drivers from MotioninJoy is not stable enough. Thus in rare cases you can account some issues including Blue Screen Error.
N O T E 4:
