Motion in Joy Installation
Revision as of 18:10, 22 January 2013 by VMaslov (Talk | contribs)
Pairing
Unplug PS Move device from the computer and press PS button on it. Red LED should constantly glow. This means that pairing succeeds.
Detection in iPi Recorder
Following instructions can be found in Getting started with motion controllers article.
Notes
N O T E   1:
N O T E   2:
    • click Driver Manager
    • click Roll back
N O T E   3:
Drivers from MotioninJoy is not stable enough. Thus in rare cases you can account some issues including Blue Screen Error.
N O T E   4:
