Motion in Joy Installation
Revision as of 18:10, 22 January 2013 by VMaslov (Talk | contribs)
Pairing
Detection in iPi Recorder
Following instructions can be found in Getting started with motion controllers article.
Notes
N O T E   1:
N O T E   2:
    • click Driver Manager
    • click Roll back
N O T E   3:
Drivers from MotioninJoy is not stable enough. Thus in rare cases you can account some issues including Blue Screen Error.
N O T E   4:
