Calibration
Importance of high frame rate
Glowing Marker
- Important! Do not turn off the light in the room during calibration! This will not help the software but will make it harder for you to see what is happening on recorded video when you view it later.
Start video recording.
Tip. You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight hand away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
- First two seconds of video do not contain marker
Step 5: process calibration video in iPi Mocap Studio
- Load your calibration video to iPi Mocap Studio
- VERY IMPORTANT: Adjust the Region of Interest to cover the part of video that contains the glowing marker.
- Set initial positions of cameras. Move and rotate virtual cameras so that their positions and orientations very roughly correspond to real positions and orientations. Click “Calibrate” button on “Calibration” tab and wait while the system finishes calibration.
- Calibration algorithm may occasionally fail to find correct camera position. In particular, this may happen if left and right cameras are swapped. If this happens, move virtual cameras using camera orbit control on “Scene” tab and click “Calibrate” again. This will cause calibration (but not marker tracking) to be repeated.
Follow video tutorial:
Step 6: Define ground plane
