Calibration
Revision as of 17:37, 13 February 2013 by VMaslov (Talk | contribs)
Importance of high frame rate
Glowing Marker
Start video recording.
Tip. You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight hand away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
  • Most of the time marker is visible in at least 3 cameras and not completely obscured by human body
Step 5: process calibration video in iPi Mocap Studio
  • Load your calibration video to iPi Mocap Studio
  • Important. Adjust the Region of Interest to cover the part of video that contains the glowing marker.
  • Set the Diagonal Field of View (FOV) for your cameras on the “Scene” tab. If you use Sony PlayStation Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
  • Set initial positions of cameras. Move and rotate virtual cameras so that their positions and orientations very roughly correspond to real positions and orientations. Click “Calibrate” button on “Calibration” tab and wait while the system finishes calibration.
  • Calibration algorithm may occasionally fail to find correct camera position. In particular, this may happen if left and right cameras are swapped. If this happens, move virtual cameras using camera orbit control on “Scene” tab and click “Calibrate” again. This will cause calibration (but not marker tracking) to be repeated.
Follow video tutorial:
Step 6: Define ground plane
Step 8: Save calibration result into *.scene.xml file
