Calibration
Revision as of 18:10, 13 February 2013 by VMaslov (Talk | contribs)
Importance of high frame rate
Glowing Marker
Start video recording.
Tip. You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight hand away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
  • Most of the time marker is visible in at least 3 cameras and not completely obscured by human body
Step 5: process calibration video in iPi Mocap Studio
  • Load your calibration video to iPi Mocap Studio
  • Important. Adjust the Region of Interest to cover the part of video that contains the glowing marker.
  • Set the Diagonal Field of View (FOV) for your cameras on the “Scene” tab. If you use Sony PlayStation Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
  • Go to “Calibration” tab. Check “Auto detect initial camera positions” checkbox. Click “Calibrate” button and wait while the system finishes calibration.
  • Calibration algorithm may occasionally fail to find correct camera positions. If this happens, you should manually adjust initial camera positions to roughly match your configuration. The main thing is the correct order of the cameras around the capture area, and their approximate view directions.
    • Reset camera positions with one of the standard half-circle or full circle configurations that best suits your configuration.
    • For each camera that requires adjusting, switch to this camera using the toolbar button, and correct its position using controls on the “Scene” tab.
    • Uncheck “Auto detect initial camera positions” checkbox.
    • Click “Calibrate” button. This will rerun calibration process, without recomputing marker positions.
Tip. When doing manual camera positioning, you may find useful to match model's position with the actor on a video:
  • Select the frame where the actor is standing relatively straight.
  • Show the model by checking the "View > Skin" menu item.
  • Adjust the camera position to fit the model with the actor's image.
Follow video tutorial:
Step 6: Define ground plane
Step 8: Save calibration result into *.scene.xml file
