Calibration
Importance of high frame rate
Glowing Marker
- Important! Do not turn off the light in the room during calibration! This will not help the software but will make it harder for you to see what is happening on recorded video when you view it later.
Start video recording.
Tip. You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight hand away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
Step 5: process calibration video in iPi Mocap Studio
- Load your calibration video to iPi Mocap Studio
- Important. Adjust the Region of Interest to cover the part of video that contains the glowing marker.
- Go to “Calibration” tab. Check “Auto detect initial camera positions” checkbox. Click “Calibrate” button and wait while the system finishes calibration.
- Calibration algorithm may occasionally fail to find correct camera positions. If this happens, you should manually adjust initial camera positions to roughly match your configuration. The main thing is the correct order of the cameras around the capture area, and their approximate view directions.
- Reset camera positions with one of the standard half-circle or full circle configurations that best suits your configuration.
- For each camera that requires adjusting, switch to this camera using the toolbar button, and correct its position using controls on the “Scene” tab.
- Uncheck “Auto detect initial camera positions” checkbox.
- Click “Calibrate” button. This will rerun calibration process, without recomputing marker positions.
Follow video tutorial:
Tip. When doing manual camera positioning before the calibration, you may find useful to match model's position with the actor on a video:
- Select the frame where the actor is standing relatively straight.
- Show the model by checking the "View > Skin" menu item.
- Adjust the camera position to fit the model with the actor's image.
Step 6: Define ground plane
