Revision as of 23:01, 1 April 2013 by VMaslov (Talk | contribs)
What's this for
Equipment
PlayStation Move
Wii Remote with MotionPlus
  • PlayStation Move
  • Wii Remote with MotionPlus
Warning. On Windows 8, PS Move may not work properly using the standard Bluetooth drivers included with the OS. It is recommended to install Motion in Joy drivers.
Getting into Recorder
Device list
    • Select + Move — White
    • Select + Cross — Blue
    • Select + Square — Magenta
    • Select + Triangle — Green
    • Select + Circle — Red
    • Select + T (Trigger) — Cyan
    • Select + Start — Yellow
    • Select + PS — Off
Tips on action video
Aiming at a camera
Standard grip
  1. At some moment during the record (for example, at the beginning), you should aim with (each) motion controller at one of the cameras. It is needed to correctly orient the motion controller within the scene coordinate space in iPi Mocap Studio.
Now, the tips:
Tracking
Motion Controllers tab
And finally — applying the motion controller's data to the hand's rotation. First, determine you region of interest. Ensure that within this region the actor maintain a fixed grip of the controller. Frames with different grip should be processed separately. Next, select some frame within the region where the hand's orientation may be adjusted manually to match the actor without much effort. Make these adjustments. When ready, just press the Apply Motion Data button — and in all frames within ROI, the hand's orientation will be set automatically. This step should be done before post-processing (Jitter Removal etc.), otherwise post-processing results will be lost.
Tutorials and demos
