Keyboard Shortcuts (iPi Mocap Studio)
Revision as of 17:03, 31 July 2013 by Andrew (Talk | contribs)
Timeline Navigation
space
— Play/pause (also stops active processing pass if any)
M
— Go to the first frame of region of interest (if current position belongs to it) or to the first frame of video (if current position is out of region of interest)
— Go to the previous frame
— Go to the next frame
— Go to the last frame of region of interest (if current position belongs to it) or to the last frame of video (if current position is out of region of interest)
I
— Set the beginning of region of interest to the current frame
O
— Set the end of region of interest to the current frame
3D Tools and Cameras Switching
1
— Switch to the first camera view (same as clicking on Camera 1 button in the toolbar)
2
— Switch to the second camera view if exists (same as clicking on Camera 2 button in the toolbar)
3
— Switch to the third camera view if exists (same as clicking on Camera 3 button in the toolbar)
4
— Switch to the fourth camera view if exists (same as clicking on Camera 4 button in the toolbar)
5
— Switch to the fifth camera view if exists (same as clicking on Camera 5 button in the toolbar)
6
— Switch to the sixth camera view if exists (same as clicking on Camera 6 button in the toolbar)
S
— Switch to selection tool (same as clicking on Select button in the toolbar
Q
— Switch to move tool (same as clicking on Move button in the toolbar
W
— Switch to rotation tool (same as clicking on Rotate button in the toolbar
E
— Switch to inverse kinematic (IK) tool (same as clicking on IK button in the toolbar
Skeleton Navigation
— Move to the parent bone
— Move to the child bone if exists or to the next sibling bone otherwise
Shift
— Move to the previous sibling bone (cyclic)
Shift
— Move to the next sibling bone (cyclic)
Processing Commands
Ctrl
Shift
— Track forward
Ctrl
Shift
— Track backward
Ctrl
Shift
R
— Refit pose
Ctrl
Shift
J
— Apply jitter removal
Ctrl
Shift
A
— Analyze actor appearance
Ctrl
Shift
— Increase trajectory filtering
Ctrl
Shift
— Decrease trajectory filtering
File Commands
Ctrl
N
— Create new project from .iPiVideo file (same as clicking on New button in the toolbar)
Ctrl
O
— Open existing project file (.iPiMocap or .iPiMocapTrial) from disk (same as clicking on Open button in the toolbar)
Ctrl
S
— Save current project to disk (same as clicking on Save button in the toolbar)
Ctrl
I
— Open animation from BVH/FBX/SMD file for playback
Ctrl
T
— Import target character from BVH/FBX/DAE/SMD/DMX file for motion transfer
Ctrl
E
— Export resulting animation for region of interest as BVH/FBX/DAE/SMD/DMX file
Edit Commands
Ctrl
Z
— Undo the latest changes
Ctrl
Y
— Redo the latest changes which have been undone before
Ctrl
C
— Copy entire character pose to Clipboard (use Ctrl+V to paste)
Ctrl
B
— Copy selected bone rotation to Clipboard (use Ctrl+V to paste)
Ctrl
Shift
C
— Copy rotations of selected bone and all its children (including all descendants) to Clipboard (use Ctrl+V to paste)
Ctrl
V
— Paste character pose (entire or separate bones) from Clipboard to current frame
Ctrl
Shift
V
— Paste character pose (entire or separate bones) from Clipboard to all frames of region of interest
Ctrl
D
— Delete character pose in current frame that will reset it to default T-pose
Ctrl
L
— Load character pose (entire or separate bones) from file on disk to Clipboard (after loading pose can be paste using Ctrl+V)
Ctrl
P
— Save character pose (entire or separate bones) from Clipboard to file on disk (this command is available if pose was copied to Clipboard using one of the Ctrl+C, Ctrl+Shift+C, Ctrl+B commands)
Batch Commands
Ctrl
Shift
B
— Start/stop adding passes to the current batch
