Biomechanical Analysis
Starting from version 2.6, iPi Mocap Studio includes iPi Biomech Extension.
iPi Biomech Extension is a convenient tool for in-depth biomechanical analysis on tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
- Sports motion analysis
With iPi Biomech Extension you can:
Note. iPi Biomech Extension requires separate license key, which you need to activate in addition to iPi Mocap Studio license key. 30-days free trial provided.
- Switch to Biomech tab.
- Press Activate button
Select Data for Analysis
- Select bones
- Check corresponding bones to include them in analysis
- On the top of the list you can see "special" bones - Center of mass, Center of mass projection to the ground. The rest of the list are bones from internal iPi rig.
- You can include finger bones into analysis by expanding hand bone (RHand and / or LHand). However, fingers are not tracked due to insufficient resolution of off-the-shelf cameras, so they just keep attached to hand joint (RHand or LHand), remaining in default position related to hand
- You can select all bones by clicking to checkbox in the header. Fingers will be included only if hand bone is expanded.
- Select metrics
- There are two group of metrics - linear and angular
