Biomechanical Analysis
Revision as of 18:12, 11 February 2014 by Pavel (Talk | contribs)
Starting from version 2.6, iPi Mocap Studio includes iPi Biomech Extension.
iPi Biomech Extension is a convenient tool for in-depth biomechanical analysis on tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
  • Sports motion analysis
With iPi Biomech Extension you can:
  • Get various metrics for selected bones, including
  • Plot values of selected metrics
Note. iPi Biomech Extension requires separate license key, which you need to activate in addition to iPi Mocap Studio license key. 30-days free trial provided.
  1. Switch to Biomech tab.
  2. Press Activate button
Select Data for Analysis
  1. Select bones
    1. Check corresponding bones to include them in analysis
    2. On the top of the list you can see "special" bones - Center of mass, Center of mass projection to the ground. The rest of the list are bones from internal iPi rig.
    3. You can include finger bones into analysis by expanding hand bone (RHand and / or LHand). However, fingers are not tracked due to insufficient resolution of off-the-shelf cameras, so they just keep attached to hand joint (RHand or LHand), remaining in default position related to hand
    1. You can select all bones by clicking to checkbox in the header. Fingers will be included only if hand bone is expanded.
  2. Select metrics
    There are two group of metrics - linear and angular
Plot Data
Export Motion Data
Export Point Cloud
