Biomechanical Analysis
Revision as of 17:19, 12 February 2014 by Pavel (Talk | contribs)
Starting from version 2.6, iPi Mocap Studio includes iPi Biomech Extension.
iPi Biomech Extension is a convenient tool for in-depth biomechanical analysis on tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
  • Sports motion analysis
With iPi Biomech Extension you can:
  • Plot values of selected metrics
Note. iPi Biomech Extension requires separate license key, which you need to activate in addition to iPi Mocap Studio license key. 30-days free trial provided.
  1. Switch to Biomech tab.
  2. Press Activate button
Select Data for Analysis
  1. Select bones
  2. Select Linear Quantities for analysis
  3. Select output Units for each quantity
  4. Select linear Coordinate system
  5. Select Angular Quantities for analysis
  6. Select output Units for each quantity
  7. Select angular Coordinate system
Plot Data
Export Motion Data
Export Point Cloud
