Biomechanical Analysis
Starting from version 2.6, iPi Mocap Studio includes iPi Biomech Extension.
iPi Biomech Extension is a convenient tool for in-depth biomechanical analysis on tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
- Sports motion analysis
With iPi Biomech Extension you can:
Note. iPi Biomech Extension requires separate license key, which you need to activate in addition to iPi Mocap Studio license key. 30-days free trial provided.
- Switch to Biomech tab.
- Press Activate button
Select Data for Analysis
- Select bones
- (1) Check corresponding bones to include them in analysis
- (2) On the top of the list you can see "special" bones - Center of mass, Center of mass projection to the ground. The rest of the list are bones from internal iPi rig.
- (3) You can include finger bones into analysis by expanding hand bone (RHand and / or LHand). However, fingers are not tracked due to insufficient resolution of off-the-shelf cameras, so they just keep attached to hand joint (RHand or LHand), remaining in default position related to hand
- (4) You can select all bones by clicking to checkbox in the header. Fingers will be included only if hand bone is expanded.
- (5) You can change bones listbox height using splitter at the bottom.
- Select linear quantities for analysis
- Select output units for each quantity
- Select linear coordinate system
- Select angular quantities for analysis
- Select angular coordinate system
