Biomechanical Analysis
Revision as of 18:19, 12 February 2014 by Pavel (Talk | contribs)
iPi Biomech Add-on is a convenient tool for in-depth biomechanical analysis on tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
  • Sports motion analysis
  • Plot values of selected metrics
Glossary
Linear quantities
  • Coordinate
  • Velocity
  • Acceleration
Angular quantities
Quantities derived from Euler angle of bone, include:
Linear coordinate system
  • Absolute (relative to ground) - axis are shown by selecting Move tool; center is automatically set during calibration (it's z-coordinate is always 0)
  • Relative to center of mass - axis are shown by selecting Move tool; center is in the actor model center of mass
  • Relative to parent joint - axis are shown by selecting Move tool; center coincides with the coordinates of parent bone
Angular coordinate system
Euler angles system
Unit
  1. Switch to Biomech tab.
  2. Press Activate button
Select Data for Analysis
  1. Select bones
  8. Select Euler angles system
Plot Data
Export Motion Data
Export Point Cloud
