Biomechanical Analysis
iPi Biomech Add-on is a convenient tool for in-depth biomechanical analysis on tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
- Sports motion analysis
Glossary
- Linear quantities
- Quantities derived from linear coordinate of joint in which bone is connected to parent bone, include:
- Coordinate
- Velocity
- Acceleration
- Angular quantities
- Quantities derived from Euler angle of bone, include:
- Linear coordinate system
- Coordinate system used for linear quantities, can be:
- Absolute (relative to ground) - axis are shown by selecting Move tool; center is automatically set during calibration (it's z-coordinate is always 0)
- Relative to center of mass - axis are shown by selecting Move tool; center is in the actor model center of mass
- Relative to parent joint - axis are shown by selecting Move tool; center coincides with the coordinates of parent bone
- Angular coordinate system
- Coordinate system used for angular quantities, can be:
- Absolute (relative to ground) - in this system rotations are defined relative to ground
- Local (Relative to parent bone) - in this system rotations are defined relative to parent bone
- Euler angles system
- Set of rotations which defines Euler angles, see here
- Unit
- Measurement unit of physical quantity
- Switch to Biomech tab.
- Press Activate button
Select Data for Analysis
- Select bones
- (1) Check corresponding bones to include them in analysis
- (2) On the top of the list you can see "special" bones - Center of mass, Center of mass projection to the ground. The rest of the list are bones from internal iPi rig.
- (3) You can include finger bones into analysis by expanding hand bone (RHand and / or LHand). However, fingers are not tracked due to insufficient resolution of off-the-shelf cameras, so they just keep attached to hand joint (RHand or LHand), remaining in default position related to hand
- (4) You can select all bones by clicking to checkbox in the header. Fingers will be included only if hand bone is expanded.
- (5) You can change bones listbox height using splitter at the bottom.
- Select linear quantities for analysis
- Select output units for each quantity
- Select linear coordinate system
- Select angular quantities for analysis
- Select angular coordinate system
- Select Euler angles system
