Biomechanical Analysis
Revision as of 11:35, 13 February 2014 by Pavel (Talk | contribs)
iPi Biomech Add-on is a convenient tool for in-depth biomechanical analysis on tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
  • Sports motion analysis
  • Plot values of selected metrics
Glossary
Linear quantities
  • Coordinate
  • Velocity
  • Acceleration
Angular quantities
Quantities derived from Euler angle of bone, include:
Linear coordinate system
  • Absolute (relative to ground) - axis are shown by selecting Move tool; center is automatically set during calibration (it's z-coordinate is always 0)
  • Relative to center of mass - axis are shown by selecting Move tool; center is in the actor model center of mass
  • Relative to parent joint - axis are shown by selecting Move tool; center coincides with the coordinates of parent bone
Angular coordinate system
Euler angles system
Unit
  1. Switch to Biomech tab.
  2. Press Activate button
Select Data for Analysis
  1. Select bones
  8. Select Euler angles system
Plot Data
  1. Select Region-of-Interest
    Plot window will be opened. If it is already opened it's contents will be updated. In Plot window you see Bones in rows and Quantities in columns. Plot controls:
  4. Reload plot data reloads plots data. Useful when selection of Bones, Quantities, Region-of-Interest changed or any tracking / refined / filtering applied. The same effect as if you press Plot button.
  5. Scroll to current frame button shifts all plots along horizontal axis, in order current frame to be in visible plot area. Nothing happens, if current frame is already visible on plots.
  6. Show / hide series button allows to select particular components of corresponding Quantity that will be shown on graph.
Export Motion Data
  3. Select export option:
    • Copy to clipboard / paste to Excel: text data will be copied to clipboard. You just need to open empty Excel sheet and paste. Information on parameters such as coordinate systems and units will be in top rows.
    • MATLAB file': binary file in MATLAB format.
Export Point Cloud
