Biomechanical Analysis
iPi Biomech Add-on is a convenient tool for in-depth biomechanical analysis of tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
- Sports motion analysis
Glossary
- Linear quantities
- Quantities derived from linear coordinate of joint in which bone is connected to parent bone, include:
- Coordinate
- Velocity
- Acceleration
- Angular quantities
- Quantities derived from Euler angle of bone, include:
- Linear coordinate system
- Coordinate system used for linear quantities, can be:
- Absolute (relative to ground) - axes are shown by selecting Move tool; center is automatically set during calibration (it's z-coordinate is always 0)
- Relative to center of mass - axes are shown by selecting Move tool; center is in the actor model center of mass
- Relative to parent joint - axes are shown by selecting Move tool; center coincides with the coordinates of parent bone
- Angular coordinate system
- Coordinate system used for angular quantities, can be:
- Absolute (relative to ground) - in this system rotations are defined relative to ground
- Local (Relative to parent bone) - in this system rotations are defined relative to parent bone
- Euler angles system
- Set of rotations which defines Euler angles, see here
- Unit
- Measurement unit of physical quantity
- Switch to Biomech tab.
- Press Activate button
Select Data for Analysis
- Select bones
- (1) Check corresponding bones to include them in analysis
- (2) On the top of the list you can see "special" bones - Center of mass, Center of mass projection to the ground. The rest of the list are bones from internal iPi rig.
- (3) You can include finger bones into analysis by expanding hand bone (RHand and / or LHand). However, fingers are not tracked due to insufficient resolution of off-the-shelf cameras, so they just keep attached to hand joint (RHand or LHand), remaining in default position related to hand
- (4) You can select all bones by clicking to checkbox in the header. Fingers will be included only if hand bone is expanded.
- (5) You can change bones listbox height using splitter at the bottom.
- Select linear quantities for analysis
- Select output units for each quantity
- Select linear coordinate system
- Select angular quantities for analysis
- Select angular coordinate system
- Select Euler angles system
Plot Data
- Select Region-of-Interest
- Press Plot Selected Data button
- Plot window will be opened. If it is already opened it's contents will be updated. In Plot window you see Bones in rows and Quantities in columns. Plot controls:
- Plot controls button shows plot control keys (focus should be set to Plot window).
- Mouse wheel - zoom in / out for the horizontal axis
- 'Page Up' key - zoom in for the horizontal axis
- 'Page Down' key - zoom out for the horizontal axis
- Right mouse button drag over plots - horizontal shift of all plots
- Left mouse button drag over table header title - change columns order
- 'Right arrow' key - shift all plots to the left
- 'Left arrow' key - shift all plots to the right
- Left mouse key click - show plot values for particular frame
- 'A' key - cancel zoom and shift, restore initial state of all plots
- Reload plot data reloads plots data. Useful when selection of Bones, Quantities, Region-of-Interest changed or any tracking / refined / filtering applied. The same effect as if you press Plot button.
- Scroll to current frame button shifts all plots along horizontal axis, in order current frame to be in visible plot area. Nothing happens, if current frame is already visible on plots.
- Show / hide series button allows to select particular components of corresponding Quantity that will be shown on graph.
Export Motion Data
- Press Export Selected Data button
- Select export option:
- Tab-separated text file: text format easily importable to Excel. Header will contain information on parameters such as coordinate systems and units
- Copy to clipboard / paste to Excel: text data will be copied to clipboard. You just need to open empty Excel sheet and paste. Information on parameters such as coordinate systems and units will be in top rows.
- MATLAB file: binary file in MATLAB format.
Export Point Cloud
- Select cameras you want to export point cloud from (if you select several cameras, you will get one aggregate point cloud)
- Turn on / off background subtraction (if checked, background will be included in point cloud)
- Turn on / off RGB export (if checked, color information will be added to point cloud's points)
- One point cloud from current frame (PCD): export single point cloud from current frame to file in PCD format
- All frames of ROI (multiple PCD files): export multiple point clouds (one point cloud from each frame of Region-of-Interest) to PCD format, each point cloud is saved to separate file
- One point cloud from current frame (MAT): export single point cloud from current frame to file in MATLAB format
- All frames of ROI (MAT): export multiple point clouds (one point cloud from each frame of Region-of-Interest) to file in MATLAB format
Biomech Export Profile
You can save all interface settings (1) to an XML file, and later load them from file (2). The following settings are stored:
- Selected bones, bones list view height
- Selected quantities, coordinate systems, euler angles system, units
- Settings of point cloud export
- Plot window settings (order on columns, visible series, window size and position)
