Biomechanical Analysis
Revision as of 15:23, 14 February 2014 by Pavel (Talk | contribs)
iPi Biomech Add-on is a convenient tool for in-depth biomechanical analysis of tracking data. It includes visualization of tracking data and its export to various formats. It can be used for:
  • Sports motion analysis
Glossary
Linear quantities
  • Coordinate
  • Velocity
  • Acceleration
Angular quantities
Quantities derived from Euler angle of bone, include:
Linear coordinate system
  • Absolute (relative to ground) - axes are shown by selecting Move tool; center is automatically set during calibration (it's z-coordinate is always 0)
  • Relative to center of mass - axes are shown by selecting Move tool; center is in the actor model center of mass
  • Relative to parent joint - axes are shown by selecting Move tool; center coincides with the coordinates of parent bone
Angular coordinate system
Euler angles system
Unit
  1. Switch to Biomech tab.
  2. Press Activate button
Select Data for Analysis
  1. Select bones
  8. Select Euler angles system
Plot Data
  1. Select Region-of-Interest
    Plot window will be opened. If it is already opened it's contents will be updated. In Plot window you see Bones in rows and Quantities in columns. Plot controls:
  4. Reload plot data reloads plots data. Useful when selection of Bones, Quantities, Region-of-Interest changed or any tracking / refined / filtering applied. The same effect as if you press Plot button.
  5. Scroll to current frame button shifts all plots along horizontal axis, in order current frame to be in visible plot area. Nothing happens, if current frame is already visible on plots.
  6. Show / hide series button allows to select particular components of corresponding Quantity that will be shown on graph.
Export Motion Data
  3. Select export option:
    • Copy to clipboard / paste to Excel: text data will be copied to clipboard. You just need to open empty Excel sheet and paste. Information on parameters such as coordinate systems and units will be in top rows.
Export Point Cloud
  2. Select cameras you want to export point cloud from (if you select several cameras, you will get one aggregate point cloud)
  3. Turn on / off background subtraction (if checked, background will be included in point cloud)
  4. Turn on / off RGB export (if checked, color information will be added to point cloud's points)
  6. Select export option:
    • One point cloud from current frame (PCD): export single point cloud from current frame to file in PCD format
    • All frames of ROI (multiple PCD files): export multiple point clouds (one point cloud from each frame of Region-of-Interest) to PCD format, each point cloud is saved to separate file
    • One point cloud from current frame (MAT): export single point cloud from current frame to file in MATLAB format
    • All frames of ROI (MAT): export multiple point clouds (one point cloud from each frame of Region-of-Interest) to file in MATLAB format
Biomech Export Profile
You can save all interface settings (1) to an XML file, and later load them from file (2). The following settings are stored:
