Biomechanical Analysis
Revision as of 14:39, 19 February 2014 by Andrew (Talk | contribs)
  • Sports motion analysis
Glossary
Linear quantities
  • Coordinate
  • Velocity
  • Acceleration
Angular quantities
Linear coordinate system
  • Absolute (relative to ground) - axes are shown by selecting Move tool; center is automatically set during calibration (it's z-coordinate is always 0)
  • Relative to center of mass - axes are shown by selecting Move tool; center is in the actor model's center of mass
  • Relative to parent joint - axes are shown by selecting Move tool; center coincides with the coordinates of the parent bone
Angular coordinate system
  • Local (Relative to parent bone) - in this system rotations are defined relative to the parent bone
Euler angles system
Unit
  1. Switch to Biomech tab.
  2. Press Activate button
Select Data for Analysis
  1. Select bones
    • (2) On the top of the list you can see "special" bones - Center of mass, Center of mass projection to the ground. The rest of the list are the bones from the internal iPi rig.
  8. Select Euler angles system
Plot Data
Export Motion Data
  3. Select export option:
Export Point Cloud
  6. Select export option:
Biomech Export Profile
