Biomechanical Analysis
Revision as of 16:15, 19 February 2014 by Pavel (Talk | contribs)
  • Sports motion analysis
Glossary
Linear quantities
  • Coordinate
  • Velocity
  • Acceleration
Angular quantities
Linear coordinate system
Angular coordinate system
Euler angles system
Unit
  1. Switch to Biomech tab.
  2. Press Activate button
Select Data for Analysis
  1. Select bones
    • (2) On the top of the list you can see "special" bones - Center of mass, Center of mass projection to the ground. The rest of the list are the bones from the internal iPi rig.
  8. Select Euler angles system
Plot Data
Export Motion Data
  3. Select export option:
Export Point Cloud
  6. Select export option:
Biomech Export Profile
