- Storage system: HDD or SSD or RAID with write speed at least 55 MByte/sec
- Two Microsoft Kinect sensors, or ASUS Xtion Live sensors, or PrimeSense Carmine 1.08 sensors
iPi Mocap Studio
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
iPi Mocap Studio
Environment
Actor Clothing
Recording Process
Calibration
First configuration
Preparations
- make sure that this calibration board is good visible in both sensors (the amount of yellow is low in the area of the board).
Recording Calibration Video
- Start recording by pressing the "Start" button.
- Go to the capture area with the prepared calibration board.
- Move the board back and forth, slight tipping and banking, plus slight side-to-side rotation.
- Stop the recording by pressing the "Stop" button.
- The calibration board is good visible on the depth maps most the time
- The calibration board is moving and has variety in distances to the sensors
- The amount of yellow points is relatively small
Processing Calibration Video
- Please make sure that the ground plane is determined correctly for both sensors after calibration video opening in the iPi Studio (to switch between sensors use buttons "Camera 1" and "Camera 2" in the top toolbar).
- Set the beginning of Region of Interest (ROI) to the point where calibration plane is good visible in both sensors.
- Adjust the end of ROI:
- the length of ROI should be at leat 5 seconds (150 frames)
- Go to the Calibration tab and click "Calibrate Based on 3D Plane" button
- Please wait for the end of calibration process
- Evaluate the result:
- Save the result:
- go to the Scene tab
Second configuration
Preparations
It's mostly similar to processing of the first configuration.
Recording Actor's Performance
Performance Tips
- Enter the actor.
- Strike a T-pose.
- Action
T-pose
Takes
Iterations
- Record the videos
- Give feedback to the actor
Takes
Naming conventions
- switch to the Scene tab
- select file with scene parameters which has been saved during calibration process
- etc.
Clean-up
Cleaning up tracking gaps
Cleaning up individual frames
Tracking refinement
Export and Motion Transfer
Installation problems
How to report bugs and issues
Video Materials
- From Jimer Lins: Part 1 - Setting up your Kinects and Calibrating
- From Jimer Lins: Part 2 - Recording the Action
- From Jimer Lins: Part 3 - Processing the Recorded Action
- From Jimer Lins: see other parts
