Revision as of 22:29, 14 June 2014 by VMaslov (Talk | contribs)
What's this for
Equipment
PlayStation Move
Wii Remote with MotionPlus
Wii Remote Plus
  • PlayStation Move
  • Wii Remote with MotionPlus
Warning. On Windows 8, PS Move may not work properly using the standard Bluetooth drivers included with the OS. It is recommended to install Motion in Joy drivers.
Getting into Recorder
Device list
    • Select + Move — White
    • Select + Cross — Blue
    • Select + Square — Magenta
    • Select + Triangle — Green
    • Select + Circle — Red
    • Select + T (Trigger) — Cyan
    • Select + Start — Yellow
    • Select + PS — Off
Tips on action video
Aiming at a camera
Standard grip
Now, the tips:
Tracking
Motion Controllers tab
Tutorials and demos
